Activity › Forums › VEGAS Pro › Vegas 12, DVD Architect 5, audio levels?
  • Vegas 12, DVD Architect 5, audio levels?
    Posted by Michael Gibrall on July 14, 2013 at 9:53 am
    Hi all.
    I’m watching the VU’s on Vegas’s interface and my levels are fine.
    When I burned a DVD of my project, I didn’t have to have my TV very loud to hear the audio.
    Not that the levels are too high distorted or crushed, but it’s like the volume on the DVD burned are awful loud.
    Using Vegas 12 Pro and DVD Architect 5 comsumer version.
    Thanks in advance.
    Stephen Mann replied 13 years, 2 months ago 2 Members · 5 Replies
  • Stephen Mann
    July 14, 2013 at 2:38 pm
    Check your Dialnorm parameter.
    Do not alter the audio in your Vegas project to fix it. There is probably nothing wrong with it. The audio level of the DVD is determined by the DialNorm parameter in the “render as” template. If the DVD volume is low decrease the DialNorm parameter. In the Render As template open the Custom properties. On the Audio Service tab under Dialog normalization the default is -27 dB, change it to -30 dB (I find that -31 dB is sometimes too loud but try it and see). Then on the Preprocessing tab change both the Line mode profile and RF mode profile to None. This will let the true volume of your project through and not apply these profiles to it.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Michael Gibrall
    July 14, 2013 at 4:01 pm
    Thank you, Steve.
    I’m unfamiliar with where to change these settings. Where do I go?
    Thanks again.
  • Stephen Mann
    July 14, 2013 at 6:48 pm
    In the Render As template open the Custom properties. On the Audio Service tab under Dialog normalization the default is -27 dB. Then on the Preprocessing tab change both the Line mode profile and RF mode profile to None. This will let the true volume of your project through and not apply these profiles to it.
    Steve Mann
    http://www.mmdv.com
  • Michael Gibrall
    July 15, 2013 at 12:56 am
    Thanks for the graphic description.
    For whatever reason, custom template is greyed out when I select Dolby AC3. It isn’t greyed out when I select video renders, just audio.
    Any ideas?
  • Stephen Mann
    July 15, 2013 at 1:15 am
    Make sure you are selecting AC3 Pro, not AC3 Studio.
    Steve Mann
    http://www.mmdv.com
