Vegas 12 crashing…again
Posted by Steven J casey on January 7, 2013 at 9:47 pmCame in today, working on a short edit, Vegas is now crashing about 5 seconds into every render attempt. There are no crazy effects going on, just an P2 MXF file, a lower third, interview audio and one track of music. I put a color curve adjustment on the track and compressed the audio a bit.
I don’t even know where to start this time. Any ideas where I should check?
thx
StevenDell Precision T7500
Intel Xeon CPU X5650 @ 2.67GHz 2.66 GHz (2 processors)
60GB RAM
M-Audio FW 410
Windows 7 Ultimate
CS6
Vegas Pro 12Steve Kallenborn replied 12 years ago 5 Members · 8 Replies -
Steve Rhoden
January 7, 2013 at 11:40 pmTry uninstalling and then reinstall it. Make sure its the latest
build.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-832-4956 -
Steven J casey
January 8, 2013 at 12:06 amI tried that but still crashing. I get this error message:
Problem Description
Application Name: Vegas Pro
Application Version: Version 12.0 (Build 394) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Windows\System32\wmvencod.dll
Fault Address: 0x000007FEDAA719FD
Fault Offset: 0x00000000000019FDFault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 12.0\vegas120.exe
Process Version: Version 12.0 (Build 394) 64-bit
Process Description: Vegas Pro
Process Image Date: 2012-10-26 (Fri Oct 26) 19:26:38Any idea what all this points to?
thx for the reply.
60GB RAM
M-Audio FW 410
Windows 7 Ultimate
CS6
Vegas Pro 12 -
Mark Barton
January 8, 2013 at 2:08 amThe module looks like it is from the Windows Media Player. Was there an update recently on your system? That would explain why reinstalling Sony Vegas did not resolve the problem. Do you have a system restore point to try?
Stephen Mann
January 8, 2013 at 4:48 am“Unmanaged Exception” almost always means a driver error. Have you installed any new hardware or updated drivers recently?
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Steve Rhoden
January 8, 2013 at 10:10 amWell, it seems you have recently updated something or made
a change in your system of some kind….Hard to say which.Steve Rhoden
(Cow Leader)
1-876-832-4956 -
Steven J casey
January 8, 2013 at 3:40 pmI didn’t but the IT department might have done something. Will check it out. Thanks for the advice.
60GB RAM
M-Audio FW 410
Windows 7 Ultimate
CS6
Vegas Pro 12 -
Steve Rhoden
January 8, 2013 at 10:58 pmok
Steve Rhoden
(Cow Leader)
1-876-832-4956 -
Steve Kallenborn
September 8, 2014 at 7:53 amThe problem is due to a bug in the microsoft dll which, in one place (at offset 0x17C6), loads an address with a 32-bit instruction instead of with the 64-bit version.
This leads to errors if the address (actually on the stack) is not in the low 4 GB.
