Activity Forums VEGAS Pro Vegas 11 renderinge has more artifacts than vegas 10 (same file properties and render settings)
  • Vegas 11 renderinge has more artifacts than vegas 10 (same file properties and render settings)
    Posted by Steve Denys on November 22, 2011 at 8:02 pm
    Hey,
    I’ve read some good vegas tips on here for a while. But now I got a question for myself.
    I just updated my pc with a gtx560ti to profit from the gpu rendering in vegas 11.
    In vegas10 I always rendered with mainconcept avc at 4mbit because my vids are mainly for youtube and youtube compresses it always back to about 3.8mbit
    When rendering to mainconcept 4mbit with vegas 11 it seems like the vid has ALOT more artifacts then with vegas 10.
    First I thought it was because of gpu rendering but then turned it off and it is the same thing.
    So I did a couple of tests… These are all made with the same file properties and same render settings.
    Am I doing something wrong in vegas 11 that I can’t get the quality from vegas 10?
    Here is a frame in the shadow that is pretty dark. You see that vegas 11 4mbit is really awfull and even in some clear frames the car roof and the helmet have lots of artifacts
    Here is a shot in the shadow, I can tell you here there isn’t alot of difference between vegas 11 8mbit and vegas 10 4mbit on my screen, with a slight advantage to vegas 11 8mbit(as it should be)but Vegas 10 8mbit is the overall winner
    Steve Denys replied 14 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Steve Rhoden
    November 22, 2011 at 8:28 pm
    Interesting!
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Bruce Quayle
    November 23, 2011 at 1:19 am
    I also did a render test with Vegas 9 vs Vegas 11. As Vegas 11 recognises my “low end” Nvidia GForce 230M card, I tried it first with the card enabled. Result was clearly slower in Vegas 11 than Vegas 9. I then tried it with the card disabled. Same result.
    For the identical clip and identical render and project settings, Vegas 9 produced better render times than Vegas 11. Oops!
    Sony….Please fix this while you’re fixing all the other bugs. I don’t see why I’m expected to pay more for a version that seems clearly inferior in many ways!?!
    Bruce Quayle
  • Steve Denys
    November 23, 2011 at 5:58 am
    Maybe vegas 11 is especially made with gpu rendering in mind.
    While my vegas 10 takes about x1.7 real time to render, vegas 11 (with gpu enabled) takes about x0.5 real time
  • Thomas Roell
    November 23, 2011 at 12:24 pm
    Did you turn on the deblocking ? Mind also trying the “Sony AVC” codec with the same shots ?
    There is also this intresting link which describes more of the Mainconcept CUDA AVC codec. Maybe those limitations cause this massive blocking effect. https://www.mainconcept.com/products/sdks/gpu-acceleration/cuda-h264avc.html
  • Steve Rhoden
    November 23, 2011 at 3:05 pm
    At this point, if i was heading the Sony Creative team, i
    would see to it that a longer and more rigorous beta testing
    is carried out before releasing a new version. I would leave
    no bugs unturned….lol
    I couldnt sleep at night knowing that it takes several updates
    (.0a/.0b/.0c) to get it right….but that’s me.
    Vegas has so much potential to topple everything out their.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
  • Steve Denys
    November 23, 2011 at 3:51 pm
    Thx for the advice, I tried the deblocking but it’s actually worse then normal
    I tried the sony avc codec and the results are alot better on 4mbit, but then I get the same problem as here. The video renders without sound…
    https://forums.creativecow.net/thread/24/939229
  • Bruce Quayle
    November 23, 2011 at 7:55 pm
    When using the Sony AVC codec, be sure to go into “Custom”, click on the Audio tab and make sure that “Include Audio” is ticked – I believe that it is un-ticked by default (!??!). This should solve your audio issue.
    Cheers,
    Bruce
  • Steve Denys
    November 23, 2011 at 8:00 pm
    I know, the audio included is ticked…
    I have the same problem as these guys
