Activity Forums VEGAS Pro Vegas 11 render “streaks” at any setting
  • Vegas 11 render “streaks” at any setting
    Posted by Kert on December 22, 2011 at 8:23 pm
    I am trying to render AVC footage to mpg2 in vegas 11 (510). The resulting mpg for “DVD Architact NTSC wide angle” shows streaks when the camera moves slow or fast. I tried all settings I could think of with the same result.
    Can you suggest the right setting? Thank. JK
    Kert replied 14 years, 8 months ago 2 Members · 2 Replies
  • Malcolm Matusky
    December 23, 2011 at 12:42 am
    I have been using vp11 and am experiencing huge problems, I am reverting back to VP9 when my current project is done and will wait till a STABLE RELEASE OF THIS PROGRAM IS AVAILABLE.
    Malcolm
    http://www.malcolmproductions.com
  • Kert
    December 23, 2011 at 1:44 am
    I found the problem!
    In the “Project Properities” window, one needs to set the “Deinterlace Method” to
    “blend Fields” I had the setting at “none”.
    I am not sure if vegas 11 opens with “none” as a default or not. I’ll check. But make sure for general work “Blend Fields” is set. JK
