Activity Forums Boris FX Vegas 11 / RED 5 crashes when autosaving
  • Vegas 11 / RED 5 crashes when autosaving
    Posted by Robert St-onge on March 7, 2012 at 9:37 pm
    Still evaluating an expired Red 5 demo and was wondering if this is a known bug new to Vegas 11 build 595. Haven’t had this problem on the previous build.
    I constantly get a crash within 5 to 15 minutes timespan which is triggered when Vegas autosaves while inside RED 5. Vegas always hits the 33% saving mark and stalls.
    The .veg files gets renamed to .veg.tmp which I need to rename to .veg and then restart Vegas. I can basically trigger Red 5, do a one or two adjustments, let it sit there and then it will eventually crash on autosave.
    Mind you that I am also using Vegasaur autosave feature as well. Just before I go digging into settings, I just wanted to know if this is a known issue.
    Robert St-onge replied 14 years, 6 months ago 3 Members · 4 Replies
  • Robert St-onge
    March 8, 2012 at 4:08 am
    I should also add that RED 5 does not always crash but it will not allow you to apply or cancel your compositing.
    So basically you are composting in RED and then suddently CTRL Z doesn’t work anymore on the keyboard (but works under EDIT) and you then notice that Vegas did autosave to 33% and therefore you need to kill Vegas along with RED 5 since it will never complete it’s save.
  • Peter Mcauley
    March 8, 2012 at 2:14 pm
    Hi Robert,
    We’ll investigate to see if we can reproduce the problem in our labs and if so we’ll talk with Sony to determine whether it’s a problem on our end and something that we can fix or if it’s something that must be fixed in the host.
    Peter.
  • Jeremy Ellis
    March 8, 2012 at 5:28 pm
    Hello Robert,
    Could we please get a copy of your Sony Vegas project file. You can send that directly to me at jeremye@borisfx.com
    Thank You
    Jeremy
    Boris Support
  • Robert St-onge
    March 8, 2012 at 6:11 pm
    File is sent,
