Activity Forums VEGAS Pro Vegas 11 Pro Build 520 Render Crash
  • Vegas 11 Pro Build 520 Render Crash
    Posted by Casey J porter on March 1, 2012 at 2:25 pm
    I’ve just upgraded from Vegas Pro 9 on Windows XP to Vegas Pro 11 and Windows 7 Professional. I am currently working on a short film of 11 minutes and it is mixed format of Canon 7D, Canon Vixia, and Go Pro and Go Pro 2 footage. Some effects, titles, and clips where done on a Mac and exported as Apple Pro Res 422 HQ and Apple Pro Res 422 LT. I have a fair amount of color correction and image stabilization. However more will have to be done. As of what I’ve gotten done now I can not render anything. I’ve tried XDCAM MP4, WMV, just about everything that matches my project settings and some that don’t. I’ve eliminated everything in my project that I imported that I didn’t end up using, I’ve changed my render thread to 1, I’ve adjust my virtual memory to Initial Size of 4990mb to 90000 of 190871 available. So far nothing has worked. I’ve done a lot of searches before posting and have yet to find the answer to my problems. Below are my system specs and error report. Any answers someone could provide would be of great help to me.
    Thank You,
    Casey
    Windows 7 Professional 32bit
    Processor: AMD Phenom™ Triple-Core Processor
    RAM: 4.00 GB
    ATI Radeon HD 4600 Series
    2431 MB Total available graphics memory
    Dedicated graphics to memory 1042 MB
    Dedicated system memory 0 MB
    Shared system memory 1407 MB
    Primary Hard disk 182 Gb Free ( 298 GB Total )
    Display adapter driver version 8.850.0.0
    Direct X Version 10
    Quicktime 7.7.1
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 520)
    Problem: Unmanaged Exception (0xc00000fd)
    Fault Module: C:WindowsSYSTEM32ntdll.dll
    Fault Address: 0x76EEF9C0
    Fault Offset: 0x0001F9C0
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 11.0vegas110.exe
    Process Version: Version 11.0 (Build 520)
    Process Description: Vegas Pro
    Process Image Date: 2012-01-16 (Mon Jan 16) 22:38:32
    Casey J porter replied 14 years, 6 months ago 3 Members · 4 Replies
  • Steve Rhoden
    March 1, 2012 at 3:54 pm
    Uninstall Vegas, restart your computer, then reinstall it.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Casey J porter
    March 1, 2012 at 6:59 pm
    Ok, I can give that a shot. For my own knowledge what error does this fix? Is this something that could come back?
  • John Bean
    March 1, 2012 at 7:22 pm
    The latest Vegas Pro build is 594 (32-bit) and 595 (64-bit).
    It just came out two days ago.
    Build 520 (32-bit) was the last update release.
    Lots of fixes in build 594 that are suppose to fix a lot of problems with Vegas Pro 11.
    So firstly, you should upgrade to this latest build. If your system is 32-bit, you will need build 594. If you’re system is 64-bit, you will need build 595. It’s all on the website. It’s a FREE upgrade too.
    Some defintions:
    low-intensive = very little effects and transitions
    high-intenseve = lots of effects and transitions
    After upgrade (re-install using latest build), try a render out test for only a 3-5 seconds of your video. Try it for both a low-intensive and high-intensive section of your video. If the low-intense section renders out OK, but the high-intensive section does not, then it could be one of several things:
    1. There is bug or problems with one or more the effects being used.
    2. Your system is not powerful enough to render all those effects.
    Good luck!
  • Casey J porter
    March 1, 2012 at 8:46 pm
    Thank you very much. I’ll post the results as soon as I get them.
