Activity Forums VEGAS Pro Vegas 11 Crashing with REDONE Project!
  • Vegas 11 Crashing with REDONE Project!
    Posted by Ralph Mccarron on July 4, 2012 at 2:13 am
    I have Vegas 11 Pro Build 682 64-bit and it crashes every 15 ninutes or so when I am editing. I have a i7 64 bit 320 HHz with 12 gigs of RAM. I just built this machine myself for $800. I have a Black Magic Intensity Pro for HDMI output as well. Error below:
    Extra Information
    File: C:\Users\ME\AppData\Local\Sony\Vegas Pro\11.0\gpu_video_x64.log
    File: C:\Users\ME\AppData\Local\Sony\Vegas Pro\11.0\dx_video_grovel_x64.log
    File: C:\Users\ME\AppData\Local\Sony\Vegas Pro\11.0\svfx_video_grovel_x64.log
    File: C:\Users\ME\AppData\Local\Sony\Vegas Pro\11.0\dx_grovel_x64.log
    File: F:\Project Files\046_001.veg
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 511) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 11.0\vegas110k.dll
    Fault Address: 0x0000000180017594
    Fault Offset: 0x0000000000017594
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 11.0\vegas110.exe
    Process Version: Version 11.0 (Build 511) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2011-12-16 (Fri Dec 16) 19:10:58
    I’m running the project of a 6TB G-Raid e-Sata drive.
    I’ve seen tons of people on the web having the same problem. I uninstalled quicktime? Still crashed. Re-installed quicktime. Still crashed. Tried the e-sata drive internally on Sata. still crashed.
    Tried it on a dual core machine thru USB and it did not crash? But could not playback well cause it being a dual core? I’m ready to do a fresh re-install and I do not know what is causing this? Been working on it for 2 days….
    Tom Pauncz replied 14 years, 1 month ago 5 Members · 5 Replies
  • Jeff Schroeder
    July 4, 2012 at 2:49 am
    Ralph,
    Are you using any NewBlue plugins (audio or video)?
    I have had this problem this week after upgrading essentials 1-4. My systems were rock solid.
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • John Bolton
    July 4, 2012 at 7:39 am
    Have you looked in the Control panel… ADMIN…. event viewer to see what may of caused it? It may give you a clue
  • Ralph Mccarron
    July 4, 2012 at 9:35 pm
    No. I only have Waves Diamond plugins.
  • Matt Carlson
    July 5, 2012 at 3:56 am
    Have you tried the trick of running the vegas.exe in Vista compatability mode? If the source of your constant crashing comes from the OFX plugins finicky nature with varied equipment and/or the 32 bit math calculation errors this trick gets rid of ninety-five percent of Vegas crashes (although it adds a few annoying problems… but at least they are not crashes.)
  • Tom Pauncz
    July 5, 2012 at 6:12 pm
    I would update Vegas Pro to the latest 64bit build – 683.
    Cheers for now,
    Tom Pauncz
    (30WEST MEDiA GROUP)
