Activity Forums VEGAS Pro Vegas 10E DVD Burner Recognition
  • Vegas 10E DVD Burner Recognition
    Posted by Martin Rahn on July 8, 2011 at 1:21 am
    I noticed that when I try to burn a DVD under 10E, no burners were found and I can only create an ISO image. I uninstalled Vegas 10E and reinstalled 10D. Voila, both burners were found and I have the option of burning either a standard or Blu Ray DVD.
    Is this a bug under 10E and is there a work around so I can take advantage of the 10E fixes?
    Marty Rahn
    Dale Mcclelland replied 15 years, 2 months ago 4 Members · 4 Replies
  • John Rofrano
    July 8, 2011 at 3:33 am
    [Martin Rahn] “Is this a bug under 10E and is there a work around so I can take advantage of the 10E fixes?”
    I’m using 10.0e and all three of my DVD and Blu-ray burners show up correctly. This seems to be unique to your system. You might try installing 10.0e again. Maybe the uninstall cleared things up and it will work now?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Martin Rahn
    July 8, 2011 at 11:29 am
    John:
    I reinstalled 10E and see the burners grayed out as before. I am participating in another forum on 3D matters and noted a number of comments regarding the same problem.
    The forum is AVS and the string is Sony 10E bugs. You might find it interesting. I don’t recall the URL, but Google will bring you there.
    Regards,
    Marty
    Marty Rahn
  • Dave Petteruto
    July 8, 2011 at 11:42 am
    See this thread, it may be your answer.
    https://forums.creativecow.net/readpost/24/930461
    Dave P.
    Intel I7 950, 12GB RAM, NVIDIA GeForce GTX 460 SE, Vegas Pro 10 (32bit/64bit), Windows 7 Pro 64bit, LG WH10LS30 10X Bluray Burner.
  • Dale Mcclelland
    July 8, 2011 at 10:26 pm
    As mentioned in the thread linked by Dave P., un-checking “Use Legacy Disk Drivers” in “Options/Preferences/CD Settings tab” fixed the problem for me. My LG Blu-ray drive is now seen by Vegas 10e’s “Tools/Burn Disc/Blu-ray Disc” dialog.
    I have not tried to actually burn a disc, so I don’t know whether changing that setting fixes one thing and breaks another.
