Activity Forums VEGAS Pro Vegas 10 Stabilize
  • Vegas 10 Stabilize
    Posted by Sebastien Gravel on October 11, 2010 at 10:17 pm
    Stabilize does not show up in the effect dialogue but rather by right clicking on the video clip and choosing stabilize.
    Problem is, how do you remove stabilization if the result is not worth it?
    Never mind. Solved. Looked in the manual, p204. To remove Stabilize you have to right click the video choose Stabilize then there is a “remove” button.
    John Rofrano replied 15 years, 10 months ago 3 Members · 5 Replies
  • John Rofrano
    October 12, 2010 at 10:23 am
    [Sebastien Gravel] “Never mind. Solved. Looked in the manual, p204. To remove Stabilize you have to right click the video choose Stabilize then there is a “remove” button.”
    Also notice that the stabilized clips are added to the project media as sub-clips and to the event ask Takes! That means you can stabilize with several different settings and use the ‘T’ key to cycle through them and use Remove Takes to selectively remove them also.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Sebastien Gravel
    October 12, 2010 at 12:31 pm
    Interesting. So every sub-clip is kept? Anyway to see what settings were used, so we can learn what settings are working better?
  • Sebastien Gravel
    October 13, 2010 at 3:16 pm
    Any shortcut to know which clip is being used, beside right click/property?
    Also, just found a limitation. You can’t stabilize a clip that’s reversed and you can’t revert a stabilized clip. I suppose I could render it then reimport…
  • Matt Crowley
    October 14, 2010 at 6:41 am
    In Movie Studio HD 10 (and maybe also Vegas Pro 10), the stabilisation seems to be rendered in real-time (ie during preview or output render) rather than pre-computed/rendered as an actual video file. I notice the CPU usage increases when previewing stabilised events compared to normal events using the same source media. I think only the motion analysis is done off-line when you apply stabilisation. That might explain why stabilised clips can’t be reversed.
  • John Rofrano
    October 16, 2010 at 12:00 am
    [Sebastien Gravel] “Any shortcut to know which clip is being used, beside right click/property?”
    Try the menu item: View | Active Take Information
    ~jr
