Activity Forums VEGAS Pro Vegas 10 Pro, Rendering with audio issue
  • Vegas 10 Pro, Rendering with audio issue
    Posted by Ashley Moncada on April 25, 2013 at 2:36 pm
    Hi Everyone!
    I’ve googled far and wide, without a solution 🙁
    Couldn’t find someone having my exact problem…but most of the results were from this forum- so I am hoping y’all can help me out!
    Rendering a video with usually more than one audio/video tracks going on at once.
    At the most, 3 audio, 3 video.
    After render, the video is 100% perfect. The audio, on the other hand…
    You hear no vocals, no background music, nothing- Just a constant meep meep meep meep throughout the entire 5 minutes. After going back into Vegas I’m pretty sure that the meep meep sound is actually the first frame of my background music audio track repeating over and over. I *think*
    I have NO idea what could be causing this, so I’ll just list everything! hehe… (better to have too much info than not enough, right?)
    Original vocal audio is from video: .MOV
    (was having an issue with preview stuttering and lagging horribly, and the Sony website suggested renaming my files to .mp4, and bouncing, worked very well)!
    So now I suppose I imported as: .MP4
    Background music: WAV
    Sound effects: maybe 3 or 4 times I used a brief sound effect in .mp4
    Had an issue yesterday when I tried to render- after 6 hours I get an error message that I don’t have enough memory, and the render canceled. I definitely had enough memory- Found a solution online
    1. Changed my puter’s Data execution prevention to exclude Vegas
    2. Changed Dynamic Ram Preview max to 0, threads to 1
    Rendered with these settings:
    WMV
    1440-1080
    Bit Rate: 192kbps
    Did not customize it. Took 6 hours to render, with that horrible meep meeping.
    Am currently rendering again with these settings:
    WMV
    CBR
    64kbps,44khz
    Video:
    CBR
    WMV
    640×480
    Custom Bit Rate: Internet/LAN: 1M
    Not sure if it will work yet. Still have an estimated 5 hours of rendering time.
    I made sure that none of the tracks were muted, and that the include audio option was checked.
    I tried rendering out into .mp3 alone, and the sound was still
    meep meep meep, even without the video.
    It sounds beautiful when I bounce sections throughout, and even during regular preview.
    I’m very new to this, and this is only the third Vegas video I’ve rendered- but the other 2 came out perfectly. Any suggestions and advice would be very appreciated!! Thanks!!!!
    Ashley Moncada replied 13 years, 4 months ago 1 Member · 1 Reply
  • Ashley Moncada
    April 26, 2013 at 1:11 am
    Hi!
    My 2nd attempt finished rendering, and it works magnificently! Lol…
    Problem solved. Thanks though, to anyone who read this wanting to help!
    The video 🙂
    https://youtu.be/7-W_Tr1LhGE
