Vegas 10 – Optical Flow – Source Layer
To make an extreme slow motion effect which is longer than the source clip using BCC Optical Flow I read the manual that I’m supposed to create an empty event of desired length, add Optical Flow to the empty event, and then indicate the source layer.
This does not seem to work for me on Vegas 10 – has anyone had any success – the Souce Layer pop-up shows only Source Layer, is this feature not enabled in BCC for Vegas or am I doing something wrong?
Magnus
