vegas 10 multi camera issue.. only one camera showing up
Posted by Jeff Karp on July 1, 2013 at 5:02 pmI have a 4 camera shot and when I select them all and go to multicamera edit.. only camera 1 shows up in preview and I can’t do anything.. I highlight each one and still no go.. never had this issue before
any ideas?
Neal Barlow replied 13 years, 1 month ago 4 Members · 6 Replies -
Roger Bansemer
July 1, 2013 at 5:30 pmYou sure you use “ctrl D” to invoke the for different images in your preview window?
Roger Bansemer – PaintingAndTravel.com
Jeff Karp
July 1, 2013 at 5:58 pmctrl D doesnt do anything… all I get is one window with a blue line around it in the preview.. usually I would get divied up w/ 4 squares so I can see each vid track when I enable multi camera.. this is really annoying 🙁
also, I had to flip the first track vertically and when I enable multi it flips it back.. but that is a completely different issue I haven’t even gotten to yet 🙁
don’t get it, I’ve done this several times before.. its got to be a setting.. I just tried it with other video I have done before and still cannot do it…
Roger Bansemer
July 1, 2013 at 8:28 pmThat’s really bizarre, especially the flipping of the image. I have no idea. I think I’d try put a new instance of the video on the timeline and see if it works and if not maybe start a new project and see if it works. If it works in a new project you can always just copy and paste it over.
Jeff Karp
July 2, 2013 at 8:11 amI’ve now tried completely different files that worked before and the same thing is happening.. even on another machine w/vegas the same thing happens.. this is driving me nuts
Stephen Mann
July 2, 2013 at 3:58 pm -
Neal Barlow
July 2, 2013 at 6:11 pmVegas always seems to abandon any effects, cuts and corrects made to files once you add them to a multi-cam track. I always have to correct my footage first, and then make them tracks for multi edit if I made a correction while filming. The solo track seems like vegas isn’t seeing the other clips in the add on. If you select “takes” on the new multi-cam track, can you see all the track names now as takes?
Neal Barlow
To The Skies – Productions
The Cult Classic Returns in ZOMBIES DURING THIRD PERIOD: AGAIN
