Activity Forums VEGAS Pro VEG properties with nested projects
  • VEG properties with nested projects
    Posted by Doug Jackson on August 14, 2013 at 12:19 am
    So, when you nest VEG file(s) into a ‘Master’ VEG, which Project Properties settings are applied?
    The settings in each of the VEG segments?
    or the Project settings of the ‘Master’?
    Mostly interested in the “Full-resolution rendering quality”
    Regards,
    –Doug
    Tyson Onaga replied 13 years ago 2 Members · 1 Reply
  • Tyson Onaga
    August 14, 2013 at 4:45 pm
    The Master .veg properties is applied only on the Master; each child uses its own properties.
    Think of your nested .veg as (eg) a video clip (a file) with the properties of each .veg. The nested .veg will be an Event with its properites on the Master timeline. If parent and child have the same properties (eg, 1920×1080), then the Event will fit 1:1. If the child is smaller (eg, 1280×720), then you will need to apply Track Motion keyframes on that nested Event or Vegas will enlarge the 1280×720 Event to 1920×1080.
