Activity Forums VEGAS Pro Veg 8 – ASIO error message
  • Veg 8 – ASIO error message
    Posted by Jeff Weinberger on October 14, 2007 at 1:54 am
    Vegas 8 is giving an error message when I launch it:
    “CTASIO Warning- there are no Creative Audio products installed and running on the system that support ASIO”
    Vegas freezes until an “OK” box is checked, then it opens. Is there a way to get rid of this error box? I checked on Google and found that this exact message appears with some other apps, but did come across a solution to the problem.
    Laszlo Kovacs replied 18 years, 11 months ago 3 Members · 6 Replies
  • Douglas Spotted eagle
    October 14, 2007 at 4:35 am
    have you chosen that driver set in the Vegas Options|Preferences|Audio tab? Haven’t ever seen this message, so not sure what to suggest, it’s a shot in the dark.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Laszlo Kovacs
    October 14, 2007 at 5:17 am
    I have a Creative SB Live! Value card, and the exact same error messeage started to pop up after a SB driver update.
    It occured with Vegas 5 for me.
    I solved it with regedit, I renamed an “ASIO” key.
    Renamed only to be able to undo, if some problem appears after, but nothing bad happened – just Vegas error disappeared.
    If you’re interested in, later I’ll look it up where is this key exactly.
    By(t)e
    K.L.
  • Jeff Weinberger
    October 14, 2007 at 8:58 pm
    Laszlo,
    Please post your Registry key modification and I will give it a try.
    Spot, I went through the Vegas Prefences and could not find a box to uncheck that would deselect ASIO drivers. Actually, there is no option to choose ASIO either as I don’t have a Creative Labs card in this computer. Vegas 7e did not trigger this error, it started after I upgraded to 8.
    thanks,
    Jeff
  • Laszlo Kovacs
    October 15, 2007 at 2:40 am
    I just reinstalled my sound drivers, and error message came back:
    CTAsio warning:
    There are no Creative audio products installed an running on the system that supports ASIO.
    After pressing “OK”, Vegas continues starting, and then works without subsequent errors.
    There’s a key:
    HKEY_Local_Machine/Software/ASIO
    (under it is only Creative asio with a CLSID)
    I deleted “HKEY_Local_Machine/Software/ASIO” key again and Vegas (now 6.0) starts again without any popup.
    I recommend you to check that key, and if it’s present don’t delete at first just rename (“___ASIO” for example) so you can easy restore if anything goes wrong.
    Hope I could help
    By(t)e
    K.L.
  • Jeff Weinberger
    October 15, 2007 at 3:18 pm
    Laszlo,
    I renamed the reg key, it got rid of the error screen.
    THANKS!!
    -Jeff
  • Laszlo Kovacs
    October 15, 2007 at 5:20 pm
    I’m glad to help you.
    Just wondering how you got that key there if you don’t have any Creative Labs soundcard (with its drivers) ?
    By(t)e
    K.L.
