Activity Forums Adobe After Effects Vectors and Collapsing Transformations
  • Vectors and Collapsing Transformations
    Posted by Dan Fassnacht on January 9, 2009 at 12:36 am
    Hello,
    I’ve been doing some illustrator work and using vector files in After Effects. When I collapse a transformation or click the continually rasterize button when having a camera or effects on the vector layer it gets all distorted. I know that using the collapse transformation/cont. rasterize button messes with the render order in AE. Is there any solution to this? Or are you basically stuck with building stuff twice as big to be able to use cameras, scale attributes, effects etc? Thanks for any help or suggestions.
    -Dan
    Motion Graphics | Video Editing
    http://www.danfassnacht.com
    David Cohen replied 17 years, 5 months ago 3 Members · 2 Replies
  • Peter Van der zee
    January 9, 2009 at 11:46 am
    I don’t understand where your problems come from,
    a vectorlayer with collapsed transformation or continous rasterize
    (it’s the same thing) should just interpret the edges well at any size
    ore however close it is to the camera.
    Maybe you are precomping with a camera in each comp?
    Do a test, make a simple vector in AI and import it into AE,
    you can do anything with it and see the difference between collapsed
    and no-collapsed, it affects just the quality, nothing else
    http://www.zeemotion.com
  • David Cohen
    March 4, 2009 at 5:14 pm
    Actually I find if the transfroms are collapsed then it becomes a 2d layer and loses camera control. IT is big problem and i am trying to figure out how to handle it.
    Dave Cohen
    Motion Graphics * Digital Design
    http://www.daveswaves.net
