Activity Forums Adobe Illustrator Vector Rings
  • Vector Rings
    Posted by David Yowell on September 19, 2009 at 10:23 pm
    I am relatively new to Illustrator CS3, but do have a good understanding of how to use it. However, I am having trouble with this piece of artwork. I would like to reproduce these rings in a vector format so that I can enlarge them and not loose any of the quality. I especially need to know the best way to add the highlights of the rings. Thanks so much for your help.
    David Cabestany replied 17 years ago 2 Members · 1 Reply
  • David Cabestany
    September 22, 2009 at 6:28 am
    You can try using either the blend tool or the gradient mesh tool. A gradient won’t work because it only goes horizontally or vertically (radial won’t work either) but can’t follow
    a path like you need in here.
    Another option is to add a white stroked path and apply a blur effect on it. Effects in Illustrator are calculated each time yu scale the object but if you make it too big your file will become very slow.
