Activity Forums Adobe After Effects Vector Paint Question
  • Vector Paint Question
    Posted by Ricardo Nichols on December 12, 2006 at 3:47 pm
    At one point, I took a After Effects training course way back when, and I was shown how to draw something in Vector Paint that I then animated, that was able to ignore any pauses I made during the actual drawing. So if I was halfway through what I wanted to draw and decided I wanted to think for a second on how to change course, it managed to ignore that pause when animated and go right to where I moved to next.
    Does anyone know how to do that?
    Any help greatly appreciated.
    -Rolyn
    Jens Enqvist replied 19 years, 9 months ago 2 Members · 6 Replies
  • Jens Enqvist
    December 13, 2006 at 7:08 am
    Use the VP Comp window flyout menu or Context click in the comp window and set “Shift-Paint Records” to “Continuous”. (and hold down the shift key while painting)
    Playback Mode -> Animate Strokes
    -jens
  • Ricardo Nichols
    December 13, 2006 at 4:35 pm
    I wish I could supply more information so you could help me, but I did exactly what you described… and felt that was how I did it previously too so had tried it even before getting your info…. and still it pauses at all the places i pause. i’ve made a point to have shift down before i begin painting through when i finish and everything. i wondered if maybe because i am using a tablet that that is causing a problem, but i turned off the stylus settings too and nothin’.
    baffling.
    any ideas?
  • Jens Enqvist
    December 14, 2006 at 7:25 am
    Did you change the playback speed from the default value?
    That could cause a pause between each stroke.
  • Ricardo Nichols
    December 14, 2006 at 3:59 pm
    I’m not sure exactly what you mean…. The playback speed is by default 1.00.
    If I am supposed to change it, what do I change it to? If I raise or lower it, it just goes faster or slower, still pausing at the places I paused during drawing so that isn’t a help…
  • Jens Enqvist
    December 15, 2006 at 10:11 am
    No I meant that changing the playback speed could cause problems with continuous recordings.
    I can’t reproduce and I can’t figure out what might cause this.
    If you want, you can send me a project with continuous recorded strokes which shows this problem and I’ll have a look.
    You can send it to support(at)cycoresystems.com
  • Jens Enqvist
    December 15, 2006 at 10:13 am
    I meant, you can send it to support(at)cycorefx.com
