Activity Forums Adobe Illustrator Vector or not vector, that is the question
  • Vector or not vector, that is the question
    Posted by Mat Chevitz on July 18, 2012 at 4:33 pm
    Hi there,
    I received this document from a graphist, done in Ilustrator. Look at the A, why do I have pixels here, although this is vectorized ?
    I thought it was ok, but when I import it in AE for animation it’s not good at all… I should have miss something in Illustrator
    Thanks !
    Editor, MotionDesigner
    http://www.cebri.fr
    MacPro 2×2.8 Ghz Quad-Core Intel Xeon
    8 Go DDR2 FB-DIMM 667 MHz
    Mac OS 10.6.7
    Joseph W. bourke replied 14 years ago 3 Members · 5 Replies
  • Nevin Styre
    July 23, 2012 at 7:42 pm
    What type of file did he/she give you? vector files are typically EPS or AI (also PDF or SVG).
    In AE when working with a vector layer from a file make sure you enable the “continuously rasterize” checkbox on the layer or pixelation will occur if you enlarge it past 100% the default size.
  • Mat Chevitz
    July 23, 2012 at 8:55 pm
    I did enable the “continuously raserterize” button in AE.
    The source file is an AI file.
    Actually, the screenshots I posted are from Illustrator.
    The thing is when I zoom far from 100%, like 6400% the letter looks ok. But when I’m close to 100% it looks bad…or maybe it looks the way it should be, but that’s not how I thought vector letters would be.
    I don’t get that.
    http://www.cebri.fr
    Mac OS 10.6.7
  • Nevin Styre
    July 23, 2012 at 9:20 pm
    In Illustrator preferences do you have “anti-aliased artwork” checked off? turn it on if it is off(it’s in the general preferences). In after effects next to continuously rasterize there is also a quality switch, make sure you set that one to the solid “/” icon as the other setting disables anti-aliasing as well.
  • Mat Chevitz
    July 23, 2012 at 9:40 pm
    Anti-aliased is off and the quality icon is on the right side…
    The problem is in Illustrator. When I use the Text tool and write something, my text looks good.
    The problem is the path itself, from the graphic designer. Maybe he used a bad font, or he did something wrong with the vectorization.
    He made several text with different font each time. Some are bad like the one I showed you, but some are good…
    I think I should try to talk about it wth him now…
    http://www.cebri.fr
    Mac OS 10.6.7
  • Joseph W. bourke
    September 16, 2012 at 11:29 pm
    Something many graphic artists don’t understand is that just because a file is saved in Illustrator, it’s not necessarily a vector-based file. I’ve requested vector-based artwork from people, and had the same nasty looking results, only to find that the person thought all you had to do was open or import a bit-mapped file into Illustrator, and save it as an eps or ai file, and it was now vector-based. This is not the case, and it may be what you’re dealing with.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
