Activity Forums Maxon Cinema 4D Vector Motion Blur not showing up.
  • Vector Motion Blur not showing up.
    Posted by Piotr Raczko on February 13, 2014 at 4:46 pm
    Hi Everyone,
    I’m having trouble getting Vector Motion Blur. It doesn’t show up in render. I have a position, rotation and PBlurp morph animation in my scene. I enable Vector Motion Blur in the Render Settings. I add a Motion Blur tag for each animated object and for the Particle Geometry object, to blur the PBlurp morph too. And nothing changes in render. No effect.
    How to set it up properly?
    By the way, I particularly want to try VMB, as the Sub-Frame Motion Blur and Physical Render Motion Blur take too long to render.
    Appreciate all help, thanks.
    Piotr Raczko replied 12 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 13, 2014 at 5:42 pm
    Works fine here. Only thing I can think of is that you’ve disabled post effects in render options?
  • Piotr Raczko
    February 13, 2014 at 6:00 pm
    I just checked at home. Indeed it works. I’ll double check at work tomorrow if I have the Post Effects turned on. Thanks.
