Activity Forums Adobe After Effects Vector Magic equivilent for video? (rotoscoping?) – Waking Life; A Scanner Darkly
  • Vector Magic equivilent for video? (rotoscoping?) – Waking Life; A Scanner Darkly
    Posted by Dave Chavinsky on February 19, 2012 at 6:50 pm
    I used the program “Vector Magic” to convert a still image to a vectorized image that has a cartoony art kind of style. I would like to use effects or filters to achieve this in After Effects if possible.
    Similar to the look of the films, “Waking Life”, and “A Scanner Darkly”, which used some kind of expensive rotoscoping software as I understand.
    So, I want to film real people and turn it into an animation with filters..
    Remi Johns replied 12 years, 4 months ago 6 Members · 6 Replies
  • Brian Charles
    February 19, 2012 at 7:53 pm
  • Erik Waluska
    February 19, 2012 at 11:46 pm
    For the rotoscoping part, the rotobrush tool and/or mocha would probably be your best bets. There is plenty of info/tutorials on the cow and elsewhere about both of those tools.
  • Todd Kopriva
    February 20, 2012 at 12:46 am
    The movies that you mention used an immense amount of manual work to do this. Software helps, but it’s a huge amount of work to get a result that looks good.
    The Cartoon effect can ceratinly help, though.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Dave Chavinsky
    February 20, 2012 at 1:11 am
    That tutorial is exactly the kind of thing I was looking for. Not a big fan of the cartoon effect.. maybe I need to fool around with it a bit more or combine it with other stuff. Using an image sequence in illustrator sounds like it will give me the control and options I want.
  • Benjamin Ausmith
    February 23, 2012 at 8:09 pm
    Link’s broken– has the article moved?
  • Remi Johns
    May 17, 2014 at 9:55 am
    thanks that answer really helped with a project im working on
