Activity Forums Adobe After Effects Vector Layer Goes Blurry After Making It 3D
  • Vector Layer Goes Blurry After Making It 3D
    Posted by Jason Schoenfeld on August 13, 2020 at 10:21 pm
    Hello, I have an imported Illustrator file that goes blurry when I make any layer 3D. The layer has ‘collapse transform’ turned on. There is no camera. I have set it to both ‘Off (final resolution)’ and ‘Adaptive Resolution’ with no change. The Illustrator file has not been scaled – it is the same size as it is in Illustrator. I am using the ‘Classic 3D’ renderer and interpret footage has been set to ‘More Accurate.’
    If I uncheck 3D it goes perfectly crisp. I can scale it however. But the moment I turn on 3D it goes noticeably fuzzy. It doesn’t matter the scale. It seems like I’ve had this in the past and was able to resolve it, but I can’t seem to figure it out this time.
    Any help is appreciate it.
    Jason
    Roei Tzoref replied 6 years ago 3 Members · 4 Replies
  • Richard Garabedain
    August 17, 2020 at 2:29 pm
    hard to guess…how long have you been using after effects? maybe a screenshot would help. You are at 100% or less on your window right?
  • Jason Schoenfeld
    August 19, 2020 at 9:05 pm
    Richard, thanks for the response. As I got working with it I noticed that when I would move the layer in z-space it would go sharp (and sometimes blurry). In all, it wasn’t as noticeable when I moved the layer in z-space. Not sure why. But if I left it in the original position, or even in some position on the z-axis, it goes blurry. It just wasn’t enough to worry about in the final animation so I left it alone.
    For reference I attached the exported comp. The left side is vector w/o 3d and the right with 3d.
    Thanks again for the response.
    Jason
    August 19, 2020 at 10:05 pm
    ohh…thats normal…the blur is very slight..you wont notice it again im sure
  • Roei Tzoref
    August 20, 2020 at 11:15 pm
    you are right. 3d vector layers do get a softer anti-aliasing. I think this was always the case.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
