Activity Forums Maxon Cinema 4D Vector Import not found!
  • Vector Import not found!
    Posted by Richard Walsh on March 8, 2024 at 9:13 am
    I thought Vector Import came with C4D R25, I’m running C4D R25.117 but Vector Import does not appear anywhere.
    Richard Walsh replied 1 year ago 2 Members · 2 Replies
  • Kouraib Abdmalek
    March 8, 2024 at 11:13 am
    Hi Richard,
    It should be in the create menu or toolbar under generator, as in the attached screenshot. If you do not find it there for some reason, click Shift & C, then type in the search box “vector import”, and you will get it. You can still contact Maxon to report this defect in your version.
    I hope this helps you.
  • Richard Walsh
    March 8, 2024 at 2:47 pm
    Weirdly it wasnt there. Installed R26 and it appeared. Thanks
