Activity Forums Adobe After Effects vector art w/ continuous getting pixelated
  • vector art w/ continuous getting pixelated
    Posted by Joe Mole on November 30, 2012 at 3:04 pm
    I have a shape layer and an illustrator file in after effects CS6, that when I use a 3d Camera to zoom in on them they get pixelated. I have the continous rasterization enabled on both layers and I have the quality set to best… This only happens when I am using the camera to zoom around. . What am I missing here?
    Eduardo Asta replied 12 years, 6 months ago 3 Members · 3 Replies
  • Todd Kopriva
    November 30, 2012 at 4:10 pm
    Show us a screenshot of your Composition panel.
    After Effects team blog
  • Joe Mole
    November 30, 2012 at 9:49 pm
    I ended up using a work around where I animated the objects from the position keyframes within the layers.
    The problem was initially I wanted to do the animation via the camera layer but for some reason using the camera layer caused the pixelation.
    Ok here’s a screenshot, that red blotch is actually an illustrator file that should be text but got all blurred…:
  • Eduardo Asta
    March 6, 2014 at 12:50 am
    I am having a similar problem: I have a comp with solids, text and vectors inside and I am using a 3D camera do get closer. A null controls the camera and my zoom is linked to camera-to-null by a expression that inverts its value, so, my zoom is locked on the null object.
    Any time I change the camera position to get closer to this comp, it gets pixelated.
    Now I tried a bigger comp to be zoomed. It gets better. If I turn deep of filed of, it improves a lot, but it is not the same thing…
    If I turn on the vector quality (the little engine like icon next to layers name), my comp disappears…
    What I am doing wrong?
