Activity › Forums › Avid Media Composer › VDMV2P_TIMEOUT error in DV Express
Posted by Tim Boknecht on June 1, 2005 at 7:29 pmAnyone seen this before and know what it is / how to combat it?
Jokuh replied 21 years, 3 months ago 2 Members · 1 Reply -
1 Reply
Jokuh
June 2, 2005 at 7:22 amTaken from the avid knowledge base:
When you render fairly complex media, three video tracks, and IN
and OUT points around the area to be rendered, the following
exception might occur during the render process:
Exception: VDMV2P_TIMEOUT
Workaround: Start the render again. It might work slowly, but it will
complete the render. Restart the render as many times as it is
necessary.If you create an effect on a video track, you cannot play the effect
until you leave Effect mode. An error message appears if you
attempt to play the effect in Effect mode.
Workaround: Exit Effect mode to play the effect.If you apply a Vertical Blinds effect to the clip boundaries in a DV
50 sequence, a VDMV2P_TIMEOUT error might occur.If you import a graphic with a black background and place a Luma
Key effect on the graphic, you cannot completely turn off the
keying, even when the gain level is set to zero.
Workaround: Import the graphic using a white background.
Alternatively, for a cleaner keying effect, create and import the graphic
as a Matte Key effect.hth
jokuh
