Activity › Forums › Apple Final Cut Pro Legacy › VCR to Camcorder to Mac– not getting image on mac
  • VCR to Camcorder to Mac– not getting image on mac
    Posted by Jeri Rowland on May 18, 2005 at 12:20 am
    Hello All,
    I am trying to dub from VHS to DVD. I was originally going to go directly into FCP via a DVI adapter, taking S-out from the VCR to the mac. Unfortunately, my monitor is not Apple and uses my DVI port, making my DVI to Video adapter useless. I don’t have the ADC adapter, so I ran my VCR to my camera via RCA, then ran my camera to my mac via firewire. I’m getting the image on the camera but not in FCP. I’ve changed my Capture Settings to “non-controllable device”, but no luck. Any suggestions? My camera (if it matters) is a Panasonic DVC-30. Thanks!!
    Jeri
    Jeri Rowland replied 21 years, 4 months ago 4 Members · 4 Replies
  • Zman
    May 18, 2005 at 12:49 am
    could be many things, no e2e, cam cant fake record? but why dont u just record to a dv tape, and then dig from that. yea 2x’s long but you’ll have it all if something goes wrong.
  • Pdr
    May 18, 2005 at 1:13 am
    Hi Jeri
    I always break this step into two processes:
    1. Record from VHS VCR to miniDV tape
    2. Captuure into FCP from miniDV tape
    The best part of this is that you will have an archive of your footage with timecode that FCP can use at a later date — and your clips will be frame accurate for future reference.
    Hope this helps.
    Regards
    Peter
    raycity* media
  • Bouncing Account needs new email address
    May 18, 2005 at 11:50 am
    [jeri rowland] “My camera (if it matters) is a Panasonic DVC-30.”
    It can matter a LOT.
    Some camcorders can’t accept analog inputs at all.
    Some do but don’t “transcode” A-D out via the FireWire.
    Some WILL do this, but only if a preset in the menu (or on a switch) is set for this to occur.
    I don’t know about your camera, but you might look for a setting that says something like “A/V > DV out” (which is the Sony version of this setting.)
    All that said,
    I strongly agree that you’ll get better results if you first record an unstable analog source like VHS to a DV TAPE first, then capture the DV tape. This can even help “stabilize” the VHS (which, if captured “directly,” will likely cause capture problems with FCP due to the VHS’s horrible timebase instability.
  • Jeri Rowland
    May 18, 2005 at 12:44 pm
    Thanks to all who answered my post. I was trying to avoid the extra step of going from VHS to MiniDV simply because I have several hours of tape to dub, but it looks like that is the overwhelming opinion of those in the know. Thanks again for the advice…
