Activity Forums Compression Techniques -vcodec copy -acodec copy
  • -vcodec copy -acodec copy
    Posted by Richie Bee on June 23, 2011 at 7:41 pm
    Hi I was using -vcodec libx264 with -sameq
    and found the files were doubling in size
    so tried -vcodec copy
    and all fine and so quick to convert!
    is there any reason why I shouldn’t use -vcodec copy?
    Richie Bee replied 15 years, 2 months ago 2 Members · 2 Replies
  • Michael Rampe
    July 4, 2011 at 10:57 pm
    [richie bee] “is there any reason why I shouldn’t use -vcodec copy?”
    Depends on what you are doing.
    If you are just repacking the stream into a different container or splitting the audio from the video, -vcodec copy is the right choice as it does exactly what you would expect, copy the stream without re-encoding.
    If you are changing bitrate, size, aspect or applying filters, this is not a good choice.
    Michael
  • Richie Bee
    July 5, 2011 at 9:04 am
    thanks
