Activity Forums Broadcasting VC-1 Encoding for AT&T U-Verse
  • VC-1 Encoding for AT&T U-Verse
    Posted by Boyce Johnson on October 16, 2008 at 9:08 pm
    The municipal television channel I work for is preparing to offer our signal on AT&Ts U-Verse system. Unfortunately, due to some short-sighted state legislation we will be responsible for providing our own encoder. AT&T has provided the following specifications:
    Video Encoding Format: Windows Media Video 9 VC-1 Main Profile
    Video Streaming Bandwidth: 1.25 Mbps
    Input Video Format: NTSC
    Frame Rate: 30/29.97 fps
    Scanning Type: Non-interlaced
    Key Frame Distance: 4 Seconds
    Buffer Size: 2 Seconds
    Output Resolution: 480×480
    Captioning: Open Captions
    Audio Encoding Format: WMA (Windows Media Audio)
    Audio Streaming Bandwidth: 96 kbps
    Audio Sample Rate: 48 kHz
    Streaming Protocol: HTTP
    Streaming Mode: Constant Bit Rate
    Streaming Format: Unicast
    Addressing: Public IP Address
    Output: ASF Network Pull
    Input Physical Connection: Component, Composite or SDI
    I’m assuming the 480×480 resolution is incorrect.
    They listed a number of hardware encoders that are known to be compatible with their system. These models ranged in price from $3900 to $17,000. That seems like a huge range and I’m not sure what separates a $4K encoder from a $17K encoder.
    Although they strongly discourage it, I’m also considering building a high-end PC (dual Xeon or Opteron) with a high-quality capture card (Aja, Black Magic, etc.) and encoding via software. Assuming a fast machine and a high-quality capture card, is there any reason why something like this couldn’t put out a compliant stream that is just as good as a stream generated by a hardware encoder? Would the software used matter? Microsoft, for example, says their Expression encoder offers better VC-1 encodes than their free Windows Media encoder.
    Anyone out there dealing with this? Any Ideas?
    Scott Thorley replied 17 years, 6 months ago 2 Members · 1 Reply
  • Scott Thorley
    February 20, 2009 at 10:06 pm
    Disclaimer: I am the Product Manager for one of the encoder companies listed on the sheet you mention.
    Sorry I didn’t see your post earlier, not sure if you have already implemented a solution.
    I am very familiar with the AT&T PEG Uverse requirements, and would be happy to answer any questions. I can explain why 480×480 may seem wrong, but is correct if the encoder knows how to support it.
    You can reach me at scott(dot)thorley(at)inlethd(dot)com.
    Scott Thorley
