Activity › Forums › VEGAS Pro › VBR Question
  • VBR Question
    Posted by Carlo Simone on September 29, 2005 at 4:37 pm
    I am having difficulty understanding the VBR for Bit Rate calculation. I have a project that is 1:52.24,06 to be exact. What should my VBR be so that DVDA does not have to render it again???? Please help….Also, should I be using MPEG-2 compression. Will I see quality loss or should I render .avi?
    Thanks..
    Fotis Vassis replied 21 years ago 3 Members · 2 Replies
  • Edward Troxel
    September 29, 2005 at 4:50 pm
    VBR simply means “Variable Bit Rate”
    Your AVERAGE Bit rate must be low enough so that the file size is small enough to fit on the DVD. Otherwise DVDA would have to recompress. For 2 hours, an average bitrate of 4,825,000 with AC3 audio will work.
    Check out vol 1 #7 of my newsletters for more details (link under my name).
    Edward Troxel
    JETDV Scripts
  • Fotis Vassis
    September 30, 2005 at 6:27 pm
    Your answer is here
    https://www.interchefs.com/club/MpegCalculator.xls
    A very accurate Excel file for bit rate data budgeting plus various info about audio bit rates. Now also for DVD+DL budgeting
    Interchefs Culinary Club
    The Interactive Gourmet Experience
