Activity Forums Compression Techniques VBR Encoding WMV with Sorenson
  • VBR Encoding WMV with Sorenson
    Posted by Andrew Saliga on October 22, 2009 at 7:38 pm
    I’m using Sorenson to encode WMVs for the first time and would like to confirm I’m doing the VBR encoding correctly. I’m trying to encode the video at 7-18mbps. I chose WMV 9 Advanced as the encoder and set my data rate to 7,168kbps and the max data rate to 18,421kbps (it’s the closest I could get to 18,432kbps without going over).
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com (undergoing a much-needed redesign)
    http://www.vimeo.com/steelehouse
    Andrew Saliga replied 16 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Daniel Low
    October 22, 2009 at 7:51 pm
    [Andrew Saliga] “I’m trying to encode the video at 7-18mbps”
    Wow that’s pretty high, are you encoding 1080p?
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
    “We and Apple are neck and neck and we’re chasing the two
    other players,”
    Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
  • James Roche
    October 22, 2009 at 8:03 pm
    very sorry wrong thread!
  • Andrew Saliga
    Source is 1080 output is 720. My math is right though correct? 7mbs=7168kbps
    I’m compressing FLVs, 2 flavors of MPEG-2s, 2 flavors of WMVs…at lot of different needs for this project. I know with this particular WMV compression it’s going to be used for HDTVs.
    -Andrew Saliga
  • Daniel Low
    October 22, 2009 at 9:13 pm
    [Andrew Saliga] “My math is right though correct? 7mbs=7168kbps “
    To most people 7 Megabits per second = 7000 Kilobits per second.
    I you want to do VBR I’d aim for a peak of 14Mb/s rather than 18
    other players,”
  • Andrew Saliga
    October 22, 2009 at 9:23 pm
    Thanks Daniel.
    As for the settings in Sorenson, the “Data Rate” section…I assume when doing VBR that is the average data rate? Is there no place to set the minimum?
    -Andrew Saliga
  • Daniel Low
    October 22, 2009 at 9:52 pm
    I don’t use Sorenson but usually you set an average and a peak, the peak is usually not more than twice the average.
    other players,”
  • Andrew Saliga
    October 22, 2009 at 10:58 pm
    Thanks again Daniel. I guess if I stop and think about it, it makes sense that the peak shouldn’t be more than twice the average.
    -Andrew Saliga
