Activity Forums Adobe After Effects Vary thickness of non-vector lines
  • Vary thickness of non-vector lines
    Posted by Matthew Boutros on September 25, 2019 at 1:04 am
    Hey all, working on a custom effect to turn images into pencil drawings. It’s for an animation so it has to be procedural (I can’t be custom applying techniques to thousands of frames).
    Got it working pretty well so far, but there’s one missing ingredient I can’t work out:
    Say I have linework (not vector or stroke) – how can I vary the thicknesses of the line?
    Turbulent Displace doesn’t work because that twists the line, and Minimax is not controllable enough (doesn’t do decimals so it’s either way too much, or off).
    I can make it so we have alpha around lines if needed.
    Doesn’t need to be much either.
    Any thoughts?
    nourishingmedia.com
    Matthew Boutros replied 6 years, 11 months ago 2 Members · 2 Replies
  • Frank Feijen
    September 25, 2019 at 6:43 am
    Maybe with Roughen Edges?
  • Matthew Boutros
    September 26, 2019 at 6:36 am
    Thanks Frank, that actually does work fairly well! Just make it a thin border scaled large. I didn’t think it would be even on each side of a line (which would just make it wobbly) but it is!
    It’s a pain in the butt to have to key out the white background each time, but it’s better than nothing. (Currently, using Invert > VC Colour Vibrance with Matte Alpha > Invert, but really thought there’d be an easier way)
    But definitely better than nothing – thanks Frank!
    nourishingmedia.com
