Activity Forums Cinematography Varizoom MC100 remote head
  • Varizoom MC100 remote head
    Posted by Samuel A. martin on April 12, 2005 at 9:25 pm
    Hi all:
    I am planning to purchase the varizoom’s remote pan and tilt head this week. I was wondering what other people’s experiences with this system and how much better it is compared to the, let’s say glidecam system. Any other similar system out there for the same amount of money and looking as good as the varizoom’s? I am planning to use it with the small PD1170 and Z1 camcorders but also with the heavier Sony and JVC cameras. Will it be able to handle the heavier cameras like the sony DSR570 or the new DSR450 range? How smooth it is to use? Any problems?
    Basically, would you recommned it? why?. May be you don’t recommend it, why not?
    Thanks for your input.
    Sam
    Scotfree replied 18 years, 11 months ago 3 Members · 2 Replies
  • Jim Mulleder
    May 3, 2005 at 4:10 pm
    Look at the ads…it can only handle up to 20lbs. Depending on your set-up. with a Sony you’ll be close to 20.
    I do believe in Varizoom quality wise. Have you looked for a vari forum yet?
    Cheers
    jim
    Jim Mulleder
    Techical Producer
    https://www.telestudios.ubc.ca
  • Scotfree
    September 22, 2007 at 6:03 pm
    Hi
    Did you finally got the VariMC100 ? Is that device works properly ?
    Are you definitely into the Vari ?
    I am planning to buy the same one and what kind of advice could you
    give to me .
    Thanks a lot in advance.
    Scotfree
