Activity Forums Adobe Premiere Pro various ongoing export problems with Premiere CS3
  • various ongoing export problems with Premiere CS3
    Posted by Lon Waitman on December 18, 2008 at 10:00 pm
    Ever since I got CS3, I have had export problems in Premiere. My XVID codec doesn’t work. Also, it sometimes has problems with exporting as QT. A work-around has been to export as avi and then import into After Effects CS3 and export as XVID or QT. AE has no problems…
    Any ideas? Thanks.
    David Dobson replied 17 years, 9 months ago 2 Members · 1 Reply
  • David Dobson
    December 18, 2008 at 10:09 pm
    Your work around is the solution.
    I had a problem with Instant HD footage crashing when exporting to anything. But it would render in the timeline and then that would export as AVI. My guess is that there are incompatibilities between the codec you are exporting to and some effect you have applied to the video, because the footage is being re-rendered (whereas the avi export seems to just copy the rendered footage to a new file.) This seems to no longer be the case CS4 – where even an AVI output re-renders the effects rather than using the rendered files – but I am only guessing.
