Activity Forums Adobe After Effects Various Compositions
  • Various Compositions
    Posted by Kate Koyama on November 11, 2009 at 1:14 am
    I’ve made various compositions, so at the end I could join them all in one. But when it renders the color seems to become dull.. and some solids become semi translucent… is there anything I could do to fix that?
    Scott Novasic replied 16 years, 9 months ago 3 Members · 3 Replies
  • Anders Hattne
    November 11, 2009 at 12:02 pm
    Could you be a bit more specific, please. There are many places where this could go wrong.
    If it’s not a problem with the compression, you might not have 100% opacity on the solids or the composition nested – do you have a background layer? Check the alpha channel on all the compositions.
    good luck
    http://www.ardillamedia.com
  • Kate Koyama
    November 11, 2009 at 4:00 pm
    All my the elements in my compo had the opacity set to 100%.
    The thing is I made small compositions, and then gathered them all into one big one. So it’s a nested composition.
    Whenever I render the nested composition, the overlaps become a little transparent and the color doesn’t seem as vivid as before.
  • Scott Novasic
    November 12, 2009 at 3:34 am
    are you using 3d space in one comp and not in another? also check your compositing modes….
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
