Activity Forums Panasonic Cameras Varicam to Final Cut to SD workflow issues.
  • Varicam to Final Cut to SD workflow issues.
    Posted by John Christie on February 10, 2006 at 4:58 pm
    Hi there
    We are in the process of changing over to high def production. We have a new Varicam and 2 decks, a 1700 and a 1200. I tried a test yesterday, captured some clips into Final Cut Pro, put them in a 720P sequence and output that (via Decklink Downconvert) to DVcam. I wanted to send an OMF test to our audio house. So I output an hour long timeline to DVcam with Dropframe timecode. But when I compared the DVcam to the timeline, there seemed to be about a 3 second difference at the end of the hour. About what I would expect if there was a dropframe/nondrop discrepancy. FCP tells me that the sequence setting is 23.98, but If that’s the case, how do I time a show for broadcast, if there is no drop-frame capability? The 1700 deck let’s me choose Drop or Non Drop code when striping, but there’s no choice in FCP. Am I missing something here?
    Cheers
    John Christie
    Tony replied 20 years, 7 months ago 2 Members · 2 Replies
  • John Christie
    February 10, 2006 at 5:03 pm
    Keyframes Editing
  • Tony
    February 12, 2006 at 3:55 pm
    DF does not exist in 23.98 or 24P.
    At the end of our hour in NDF timecode you will see approximately a little over 3 secs difference when compared to the DF stripped tape.
    Tony Salgado
