Activity › Forums › Panasonic Cameras › Varicam to 4×3 SD project
  • Chris Bierlein
    October 20, 2006 at 4:43 am
    It might make sense to just down convert the footage out of the deck and edit in SD. The deck can be set up to downconvert 4:3 so you don’t have to perform that “center punch” process later, and you’ll save a little drive space.
  • Logan Kelsey
    October 20, 2006 at 7:49 pm
    Thanks, I ended up doing the down convert on capture, as suggested. Worked great.
    Cheers,
    Logan
    Vertical Online
    https://www.verticalonline.com
