Varicam timecode jamming
I have a project comming up where we will be using multicameras and will be recording sound to a DEVA V multitrack.It makes sense to use LOKIT timecode boxes to distribute timecode to the cameras unless the varicam has better timecode than previous models . The question is going to be : since the varicam is allways recording internally at 60 fps whatever the frame rate settings for shooting , if I am shooting for example at 25 fps should the DEVA and the timecode being distributed be at 60fps or 25 fps?
