Activity › Forums › Panasonic Cameras › Varicam Slow Mo footage gets jerky when a subtitle is rendered with it???HELP
  • Varicam Slow Mo footage gets jerky when a subtitle is rendered with it???HELP
    Posted by Sean Fine on July 21, 2006 at 9:36 pm
    Hi we are cuttign a doc. using Varicam footage. The footage has been brought in via 1200A
    SDI over Kona LH. Footgage shot at 60fps brought in at Panisonic DVCPRO HD 59.98 Kona setting. We used FRC to convert the footage. On some clips, not all of them, we are seeing the footgae have a few jitters or stutters when we render a subtitle over them. We have tried everything and can not come up with why this is happening. As I said it only hopens with some clips not all of them and there seems to be no comon variable in teh clips with problems. Any advcie would be appreciated.
    Gary Adcock replied 20 years, 2 months ago 2 Members · 1 Reply
  • Gary Adcock
    July 22, 2006 at 11:52 am
    [Fine Productions] ” The footage has been brought in via 1200A
    SDI over Kona LH. Footgage shot at 60fps brought in at Panisonic DVCPRO HD 59.98 Kona setting. We used FRC to convert the footage. On some clips, not all of them, we are seeing the footgae have a few jitters or stutters when we render a subtitle over them.”
    We are sorry you are ahving a problem but you post is rather vague as to details
    Was your footage shot at 60p or another frame rate – at 60p you will have 2.5x as much time with very slow motion.
    With the overlay are you rendering the footage?
    If not what color is the render bar?
    Which OS, FCP version and QT are you using
    What storage and how much is available.
    do you have enough ram?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
