Activity › Forums › Apple Final Cut Pro Legacy › Varicam slo mo in pal 25 timeline….
  • Varicam slo mo in pal 25 timeline….
    Posted by Hamish Boyd on May 18, 2007 at 2:18 am
    Hiya all,
    I’ve been trying to get a proper understanding of the workflow I should consider here.
    I’m looking at doing some commercials using varicam for some nice slow motion effects. I am delivering SD pal.
    I would like to edit in DVCproHD for grading etc and downconvert at the end.
    My question is, how do I manage 50p or 60p footage in a 25p timeline for slow mo?
    Is it a case of the deck settings when I output from a panasonic deck 1200 or 1400 and come in through firewire?
    Or do I need to go SDI in (blackmagic card) with DVCproHD codec chosen?
    I’m just not clear on the appropriate workflow for slow motion footage in 25p timeline. Everything I have read talks about 24p.
    Thanks in advance…
    Gary Adcock replied 19 years, 4 months ago 2 Members · 1 Reply
  • Gary Adcock
    May 18, 2007 at 2:41 pm
    [seamus] “My question is, how do I manage 50p or 60p footage in a 25p timeline for slow mo?”
    The Frame Rate Converter in FCP only works on the non interger frame rates- so you would need to shoot at 23.98 and then convert to 25 in CT. IT DOES NOT WORK in 25p/50i.
    “Or do I need to go SDI in (blackmagic card) with DVCproHD codec chosen?”
    That may work, I have personal issues with the way BMD captures the VFR content, and I have not been able to get it to work consistently when capturing offspeed footage.
    I have no issues correctly capturing offspeed footage (as 23.98 or at 25) via HDSDI with kona cards, so I use them exclusively.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
