Activity Forums Panasonic Cameras Varicam question
  • Varicam question
    Posted by Cartwright on August 7, 2006 at 8:47 pm
    I will try this again….
    Twice, in the past month, while using the same Varicam, I have had to deal with the ENG Security turning on without my knowledge.
    The 1st time, a card was read to the camera, causing the camera to lock up, only permitting me access to the User menus and for one reason or another, my video signal was terminated… After 8 or so attempts at regaining access to all the menus, everything was back up and working. I got all access back to every menu, and my video signal was back…
    The 2nd time I was locked out, only permitting me access to the User menus and terminating my video signal, was not from reading a card. It happened when new settings were dialed into the camera, saved as a user file. Settings that were changed were the following:
    Mater Ped, Master DTL, Master Gamma, Matrix settings, Some Color Correction 1 & 2, Some Low/Mid/High settings.
    Nothing that should change video output, or the ENG Security settings.
    Only this time the new settings were saved to the camera, not to a card. After the setting were saved to the camera, THAT
    Cartwright replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
