Activity Forums Panasonic Cameras VariCam on FinalCutPro 4.5HD
  • VariCam on FinalCutPro 4.5HD
    Posted by Mickavid on August 24, 2005 at 3:43 pm
    Is it possible to cut uncompressed VariCam footage on fcp4.5HD? If so what is the file size per 1 minute of footage?
    I am going to be overseeing post on a project where they are shooting VariCam HD. Then I want a local post facility to load the footage, uncompressed, onto my external hard drive. Then I will cut the project on a powerbook running fcp 4.5 HD. The project will be saved on the hard drive and given to the post house which will output a master to HD and make DigiBeta dubs.
    The project is a one minute commercial and a three minute video. The director predicts that he will shoot 2 hours of footage. What I need to know is – can I fit the two hours uncompressed footage onto an external drive and will fcp 4.5 HD cut the project.
    Mick
    David Battistella replied 21 years ago 5 Members · 6 Replies
  • Noah Kadner
    August 24, 2005 at 8:45 pm
    That depends what codec is being used. Are they capturing 8bit or 10-bit uncompressed to an AJA or something along those lines or capturing native DVCPROHD via Firewire?
  • Dale Mccready
    August 24, 2005 at 10:33 pm
    You will not have throughput fast enough to deal with uncompressed HD. If the footage is captured via Firewire in the DVCproHD codec then it should be fine.
  • Chris Bell
    August 24, 2005 at 10:36 pm
    You need an x-raid or other fiber raid to edit uncompressed HD. A powerbook can edit 720 24p in the DVCPROHD codec from a firewire 800 drive.
    Uncompressed HD is only really feasible on a G5, with duel processors.
    Chris Bell
  • Mickavid
    August 25, 2005 at 3:09 am
    I will be using the dvcpro codec. Thanks for the tips concerning uncompressed.
    Does this workflow work well? I have read articles that state that once the footage is in fcphd it can be onlined and fed right out to film.
    mick
  • Dale Mccready
    August 25, 2005 at 7:15 am
    What you could do from FCP if you haven’t touched it much in there is recompress the sequence media using the media manager to a 10bit codec and project (uncompressed ideally) then output the file/s from this new sequence (will not play real time now on a laptop system) to hard drive. Take this as a quicktime or image sequence to your post house for grade and film out.
  • David Battistella
    August 25, 2005 at 7:04 pm
    You might want to recapture the final cut at a 10-bit uncompressed resolution throuhg and AJA KONA2 or similar product. This plays back at 165MB/sec and the KONA 2 can do a realtime upconvert to 1080i with Varicam footage.
    If you capture the media this way for your final transcode you will be at a full 1920x1080i file size that will be more information for your film out.
    It will also be much cleaner with any renders and FX you might have.
    David
