Activity Forums Panasonic Cameras Varicam H Flare adjustment
  • Varicam H Flare adjustment
    Posted by Patrick Forestell on December 15, 2011 at 4:38 pm
    I am trying to adjust the FLARE settings on my newly
    acquired H model. I see where I can select the each ch R G B VF (from it’s default Y setting) but how do I select the SDI output to see the R G B actual VF channels ?
    I can see where the R channel is much hotter (in the VF)
    when I switch between the R G B VF Channels. I tried ball parking the hotter R Ch using the VF itself but I’d rather see the three separate channels on a waveform.
    There is no VF output mode like the P2 versions have.
    John Sharaf replied 14 years, 8 months ago 2 Members · 4 Replies
  • John Sharaf
    December 15, 2011 at 4:48 pm
    Patrick,
    Use waveform monitor in RGB mode, turn exposure up to about 1-2 stops over exposed and line up proper black on a cavity chart to zero IRE.
    JS
  • Patrick Forestell
    December 15, 2011 at 7:42 pm
    Thanks John, piece of cake with WVM set at RGB Parade using my home-made Black Hole Chart.
  • Patrick Forestell
    December 17, 2011 at 2:44 pm
    John, after setting the GAMMA and FLARE etc using the CLEAR filter how do you match the remaining filters ? Do you create 4 scene+lens files or just go with whatever the CLEAR filter has for the other three filters ?
    I ask as the manual says to do a black balance and then for the remaining filters make sure the “black dot” is the same for each filter. I assume Panasonic is suggesting that setting the camera up in CLEAR is fine for all the White Shadings+Gamma+Flare but for Black Balance, each filter has to be checked to make sure the black balance does not change when changing filters ?
    Would not FLARE also change between filters ?
  • John Sharaf
    December 17, 2011 at 3:42 pm
    Flare should not change with ND filters, Panasonic offers you a different AWB setting with each ND filter, Sony makes this optional to one AWB setting for all filters or as Panasonic does; I prefer one setting it’s more foolproof!
    JS
    JS
