Activity Forums Apple Final Cut Pro Legacy varicam downconvert to minidv
  • varicam downconvert to minidv
    Posted by Mark Fason on April 17, 2006 at 9:13 pm
    i’m starting a project next month that is going to be shot on a panasonic varicam using multiple frame rates.
    the client wants to downconvert to miniDV for the edit. if i’m digitizing the material with firewire what considerations should i have about the variable frame rates. is it possible to use the panasonic frc plug in once the footage has been downconverted? are there any other workflow obstacles i should anticipate?
    i’m a bit overwhelmed and any help would be appreciated.
    mark
    FinalCut 5.0.4
    Dual 2.7GHz PowerPC G5
    2GB DDR400 SDRAM (PC3200) – 4×512
    ATI Radeon 9650 w/256MB DDR SDRAM
    Segate 120GB external firewire drive
    Shane Ross replied 20 years, 5 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    April 17, 2006 at 10:25 pm
    Dub the camera masters to DV, and work like you always have with DV…
    Jerry
  • Shane Ross
    April 17, 2006 at 10:48 pm
    [Mark Fason] “is it possible to use the panasonic frc plug in once the footage has been downconverted?”
    That you can’t do. The variable frame rate is inherent in the DVCPRO HD footage, and that doesn’t transfer to DV. If they kept all the variable stuff to one tape, you could have a post facility dub it to another tape all slowed down. If not…I don’t know what to say. But yes, to do the FRC you need to have the footage captured as DVCPRO HD.
    Other than that, I am not sure what issues you will run into. Haven’t done it. I just know that someone who had stuff converted to DV couldn’t do the FRC thing.
    Shane
    Alokut Productions
    http://www.lfhd.net
