Activity › Forums › Panasonic Cameras › varicam down convet
varicam down convet
Posted by Joe Biscotti on October 19, 2006 at 1:38 amWill An AJHD1200 with a firewire card down convet to sd dv through the firewire? An d for extra credit–will an avid newscutter Xp control the deck via the 9 pin 422 cable?
Gary Adcock replied 19 years, 11 months ago 3 Members · 6 Replies -
Chris Bell
October 19, 2006 at 3:06 amYes. It can also down convert to DVCPRO 50.
Here is a handy web site with the deck configurations necessary for all conversions.
https://eww.pavc.panasonic.co.jp/pro-av/sales_o/ieee1394/AJ-HD1200AP_FCPHD45.html
Chris Bell
Gary Adcock
October 19, 2006 at 3:21 pm[JoeBFLL] “thanks but this is for FCP and I have an Avid system.”
How the 1200A deck functions has no consequence on which editing system you work on, as long as your avid systems is set correctly for the acquisition over FW or if you choose to use the SD – SDI port (if available)_ on the deck and capture direct into your NLE.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Joe Biscotti
October 19, 2006 at 3:44 pmThanks Gary. Does the 1400 do a HD SDI to SD SDI down convert or do you need an “external Box”?
Gary Adcock
October 19, 2006 at 5:45 pm[JoeBFLL] ” Does the 1400 do a HD SDI to SD SDI down convert or do you need an “external Box”?”
the 1400 deck has no options so can do everything you need including assemble and insert edits, unlike the 1200 deck needs the HDSDI boards for the up and down conversions.
gary adcock
Studio37
Gary Adcock
October 19, 2006 at 5:46 pm[JoeBFLL] ” Does the 1400 do a HD SDI to SD SDI down convert or do you need an “external Box”?”
gary adcock
Studio37
