Varicam 720p/24 showing up as 59.94 in Final Cut??
I recently shot a music video using the Varicam F series with 35mm lenses. The footage was captured via firewire (1200A) using the DVCPRO HD 720p/24 codec. All went well except for two clips. The first clip was shot at 720p/24 and was captured at 720p/24, but shows up in the bin as having a 59.94 Vid Rate (while all the other clips have the 23.98). I captured the clip several times and it kept showing up with a 59.94 Vid Rate.
Then I captured a clip that was shot at a 48 fps and it also shows up in the bin with a 59.94 Vid Rate and plays fast in the 23.98 sequence instead of slow motion.Has anyone ever heard of anything like this happening? I hope this is user error because I am baffled.
Thanks for your help.
