Activity Forums Apple Final Cut Pro Legacy Varicam 720p 24/60
  • Walter Biscardi
    August 5, 2007 at 9:04 pm
    [nick Franco] “720p24 (only 23.97)”
    720/24 is 23.98. You can see that is the case even if you use the Apple DVCPro HD 720/24 preset. the frame rate is 23.98.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Jeremy Garchow
    August 6, 2007 at 2:19 am
    That are settings in the Varicam to shoot 24.0 or 23.98, just like there are settings to do so in the AJ1200 and 1400 decks.
    Nick, have you tried to modify the preset for 24.0? Try going into the audio/video settings (apple-option-q) and duplicate the dvcpro HD capture preset 720p 23.98 setting and change the frame rate to 24 (from 23.98).
    Jeremy
  • Nick Franco
    August 6, 2007 at 10:33 am
    yea i did try that to no avail.
    i have worked out thet the deck will not do firewire at 23/24 and my kona kard wont do 24 frames. so for now the 422 pro ress seams to have done the trick.
    wil the varicam frame rate converter work on pro ress? i have a 10 sec sequence that i need at slowmo
    Nick
  • Jeremy Garchow
    August 6, 2007 at 3:09 pm
    No, the FRC won’t work on ProRes footage BUT your Kona card will work as an FRC if you choose an easy setup with Varicam in the title, such as AJA Kona3 720p 23.98 ProRes HQ Varicam.
    Jeremy
  • Nick Franco
    August 6, 2007 at 7:17 pm
    Hi Jeremy
    thanks for that i have only have the Kona LHe
    i’ll check it out
    Nick
  • Jeremy Garchow
    August 6, 2007 at 7:30 pm
    No worries, it’ll look like this:
    AJA Kona LHe 720p 23.98 ProRes HQ Varicam
Page 2 of 2
