Activity Forums Apple Final Cut Pro Legacy Varicam 720p 24/60 Not 59.94/23.97 and Pro res 24p
  • Varicam 720p 24/60 Not 59.94/23.97 and Pro res 24p
    Posted by Nick Franco on September 15, 2007 at 10:10 am
    Hi All
    a few weeks ago i posted sonthing re trying to capture varicam at 60/24. i thought i got round the problem by capturing the footage sdi with AJA Kona pro res 24p.
    the problem has been that we have shot on the Varicam at 60/24 not 59.94/23.97. i though i’d cracked it but no .
    i have FCP6 with The aja Kona Lhe runing on intel quad
    i’ve captured the footage at the proress 422 (hq)24psf and about a week ago i got an error message saying that i should recompress my media or recaptur (this media is not optimized for fCP6)
    i have a multi format tiime line with Proress 422 (hq)24psf and pal footage on it. it has been playing fin and then the sound slows down and it drops frames. my raid is 30% full and has an ample data rate.
    as i said it plays the footage sometimes and not others. will i have to get my tapes converted to 59.94/ 23.97 or has anyone got a get out of jail free card?
    i have a deck here AJHD1200A
    can any one help?
    i seem to be on this forum more than i’d like
    Thanks for your help in advance
    Nick
    Nick Franco replied 19 years ago 4 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    September 15, 2007 at 10:27 am
    23.98 is 24
    59.94 is 60
    those are the proper frame rates that are actually captured on tape.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Nick Franco
    September 15, 2007 at 10:36 am
    Thank Walter
    the FCP HD MANUAL says that there is a difference on the varicam between 60/ and 59.94 and that you should avoid filming(capturing) at 60
    is there any thing you can suggest?
    Nick
  • Walter Biscardi
    September 15, 2007 at 10:44 am
    I’ve never heard of that, but then I don’t run the camera. I believe your topic should probably move the Varicam forum and ask those guys.
  • Walter Biscardi
    September 15, 2007 at 10:49 am
    [walter biscardi] “I believe your topic should probably move the Varicam forum and ask those guys.”
    Just to clarify, I mean ask them if the camera shoots a true 24 and true 60. I believe it 59.94 and 23.98 are the true frame rates and those are what we have always captured 24 and 60 to in the three years or so we’ve been editing Varicam and HDX-900 footage.
  • Nick Franco
    September 15, 2007 at 11:03 am
    Thanks Walter
    i’ll try the varicam forum
    Nick
  • Gary Adcock
    September 15, 2007 at 11:21 am
    [nick Franco] “the problem has been that we have shot on the Varicam at 60/24 not 59.94/23.97.”
    Are you absolutely sure- if you just used the camera settings without going into the service menu I doubt that you actually changed the frame rate to match NTSC DF timecode.
    On the Varicam you have to set the camera to record at 60 hrz vs 59.94 and it is buried deep in the service menus. You cannot change this setting without knowledge of the camera, it is not a casual find, one must dig to find it.
    the answer is CT- it will allow you to nudge the timebase from 24 – 23.98.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Nick Franco
    September 15, 2007 at 1:40 pm
    Hi Gary
    Yes our DOP did set it at 60 hrz vs 59.94 as at the time we felt that true 24 frams was better to go back to a film print.
    i’m kicking my self. i have a big target on my pants if anyone else wants to kick me too
    Nick
  • Nick Franco
    Hi Gary
    Nick
  • Colin Mcquillan
    September 15, 2007 at 7:19 pm
    The first time I shot on a varicam I found the service menu… wasnt burried too deep,, and the joker who had the camera before me found it too and switched it to 60hrtz (amongst other things) and I had to switch it back before shooting.
    Not as easy as the average sony service menu or the 900’s,, but having no manual or previous usage of it, it took me only a couple minutes to open it up.
    Colin McQuillan
    Vancouver BC
  • Nick Franco
    September 15, 2007 at 9:49 pm
    Hi Guys looks like i’ve cracked it. the deck has converted it to the right frame rate. the trouble i had earlier seems to be that the were a couple of unmarked scense that were shot at 48fps
    Thanks for all your help
    Nick
