Activity Forums Panasonic Cameras Varicam 59.94i from 60p flagged frames (Field Order)
  • Varicam 59.94i from 60p flagged frames (Field Order)
    Posted by Jess Nottage on August 13, 2009 at 8:51 pm
    If something is shot on Varicam with 60 frames flagged, and you ingest that into an Avid 1080/59.94i project, does field 1 originate from the same frame as field 2 or do the fields come from adjacent frames?
    Jess Nottage replied 17 years ago 2 Members · 2 Replies
  • Gary Adcock
    August 14, 2009 at 2:19 pm
    [Jess Nottage] “If something is shot on Varicam with 60 frames flagged, and you ingest that into an Avid 1080/59.94i project, does field 1 originate from the same frame as field 2 or do the fields come from adjacent frames?”
    Depends on which versions of the software and hardware- so my rule is
    if you do it in hardware the higher end systems capture one interlaced field per frame.
    the software conversions are often not so kind.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflow for the Digitally Inclined
    Chicago, IL
  • Jess Nottage
    August 14, 2009 at 2:49 pm
    Thankyou for your reply Garry but what I meant was, How does the 1400 DVCPRO deck make the 1080i fields when the cross convert is set to output 720p tapes as 1080i. Does field 1 originate from frame 1 and field 2 from frame 2 (of the 60 fagged varicam frames)?
    Sorry, my original question wasn’t very well structured.
    Jess
