Activity Forums Panasonic Cameras Varicam 3700 X pattern issue
  • Varicam 3700 X pattern issue
    Posted by Fermin Branger on January 25, 2010 at 9:49 pm
    Hi, We’ve finished our first long feature film with our VARICAM 3700. All the results was amazing. We have transfered a couple of test to 35mm and the image is beautifully cinematic.
    We had only 2 problems with the camera during the shooting: a strange XXXX patern over the image (both times). The first time I assumed that it was because of the heat of the set (not so much but about 36C int.) I turned off the camera and waited about 10 min. After that the camera worked perfect again.
    The second time we were at the montains at 12C without humidity. The problem stoped when I desactivate DRS function, and it didn’t returned.
    Someone has experimented this issue?
    All the best
    Fermin
    Fermin Branger
    ALFARERIA CINEMATOGRAFICA
    Caracas, Venezuela.
    Fermin Branger replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
