Activity Forums Panasonic Cameras Varicam 2700 Syncro Shutter issue
  • Varicam 2700 Syncro Shutter issue
    Posted by Scott Rachal on January 22, 2009 at 4:49 pm
    Can anyone else duplicate this scenario and report?
    Varicam 2700
    MENU-> MAIN MENU-> CAM OPERATION->SHUTTER SPEED -> SYNCRO SCAN: ON
    MENU-> MAIN MENU-> CAM OPERATION->SHUTTER SPEED -> SYNCRO SCAN2: ON
    Enable the SYNCRO SCAN by switching the shutter toggle down, so the single triangle appears in the viewfinder, indication SYNCRO SCAN mode is on.
    When I press the SYNCRO SCAN adjustment buttons ( + – ) on the body of the camera, I get no change in the shutter operation. No change in the Viewfinder display, and no change in exposure.
    If I switch the shutter toggle down once, to invoke SYNCRO SCAN2 mode (2 triangles in the VF) and I press the SYNCRO SCAN adjustment buttons, I get new shutter speeds, indicated by a fraction of a second, and my exposure changes as I would expect.
    If I then switch the shutter toggle down through the defined shutter speeds position 1-6, back to SYNCRO SCAN mode, again, any adjustments to the SYNCRO SCAN adjustment buttons have no effect.
    Condensed version: My SYNCRO SCAN2 (Fractions) works, SYNCRO SCAN (Degrees) does not.
    Am I missing something elementary?
    If no one can reproduce this, I’ll contact Panasonic Tech support.
    -Scott
    Bobby Holbrook ii replied 17 years, 7 months ago 3 Members · 2 Replies
  • Robin Probyn
    January 23, 2009 at 1:25 am
    Dont that camera,but my HDX900 has two shutter menus, shutter speed AND also shutter select.You can have a shutter speed selected,but if its not switched on,in the other menu,if wont work..
    Just a thought…
  • Bobby Holbrook ii
    January 30, 2009 at 3:57 pm
    Young Grass Hoppa, You have much to learn.
    Chief Editor/Cinematographer
    P2 University Grad.
    Holbrook Multi-Media
