Activity Forums Apple Final Cut Pro Legacy variable speed problem with motion tab
  • variable speed problem with motion tab
    Posted by Stephen Fenn on July 5, 2010 at 2:24 pm
    When I have my clip loaded in the viewer if I go into the speed part of the motion tab I can see the line goes from the bottom left to the top right, as you would expect. However, when I load a clip from there into the timeline and double-click that and go into it’s motion tab, under the speed part there is just a flat line and I am unable to make any changes to the keyframes.
    Any ideas appreciated.
    Stephen Fenn replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
